Ethernet OAM application failed to open a communication channel with the system to communicate with the outside world.
When this happens packets can't be send out, or received from the network. See if restarting the process solves this problem. Under normal circumstances this should not happen, however if it does, please escalate to engineering.
Error
Failed to allocate global OAM packet socket, error: %errormsg%.Return Code : %retCode%
| Name | Type |
| errormsg | String |
| retCode | uInt |
